knocking
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by wren01, May 27, 2015.
  1. hey guys I've just had my steering rack and off side swivel hub recond and both track rod ends replaced but when i go from lock to lock i get a nasty bang and sometimes crunching noise don't suppose anyone else has had the same thing and what could it be? cheers
  2. I have a similar noise lock to lock, sounds like the rack is catching on something.
  3. sometimes its like a crunching noise but every now and then it goes with a right bang :confused:
  4. Did the bush get replaced on the end of the rack nsf?
  5. i assume so it was fully recond and the mechanic doing the work said before all the play that was in the rack had gone
  6. Where are you located?
  7. north yorkshire
  8. Strut top mount??
  9. its not a constant thing sometimes it doesn't do it it seems reversing and going forward again seems to trigger it :confused:
  10. When on fill lock and in bangs and get nasty are you moving
