R26 Knocking sound after new springs
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Krissg, Feb 23, 2014.
  1. Hey hey!
    I fitted some cooksport springs last week but I have a very slight knocking while manoeuvring at slow speeds. I'm almost certain it's the fronts but have re tightened every bolt I had out and no joy.
    It's fine over speed bumps and general driving.
    Any ideas??
  2. Have you checked springs are sitting properly? I had this issue in an old car. The end of the spring was not resting properly. Not sure if this is applicable to the Megane though as I've only briefly had a look.
    Cheers,
    Kurt
  3. This may be the issue, one of them is about 5mm from the stopper on the bottom of the spring so il just have to see if I can re adjust it without taking the lot apart. Thanks!
