Kill switch
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by MJ57, Jan 25, 2015.
  1. I need to wire in a killswitch for the engine. Does any one have the pin outs on ignition and coil?
  2. All the coil packs share the same live. Trace it back to the ecu & wire it in before it splits to 4 lives.
    Lee
  3. I'd like to know this also. Thanks.
  4. there is a 30amp fuse on the battery if the kill switch is put in-between that circuit the ecu/fuel pump will cut power.
  5. [TABLE]
    [TR]
    [TD] Mark
    [/TD]
    [TD] Nominal current
    [/TD]
    [TD] Description
    [/TD]
    [/TR]
    [TR]
    [TD] (1)
    [/TD]
    [TD] 30 A
    [/TD]
    [TD] protected + battery feed for fuse box, passenger compartment relay andUCH
    [/TD]
    [/TR]
    [TR]
    [TD] (2)
    [/TD]
    [TD] 350 A (Petrol)400 A (Diesel)
    [/TD]
    [TD] protected + battery feed for starting, alternator, power feed fuse rack, Pro-tection and Switching Unit
    [/TD]
    [/TR]
    [TR]
    [TD] (3)
    [/TD]
    [TD] 30 A
    [/TD]
    [TD] protected + battery feed for engine functions via the Protection and Swit-ching Unit and diesel fuel heater relay
    [/TD]
    [/TR]
    [/TABLE]
  7. Legend! Thanks.
