Juddering under boost
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by smalleys225, Jan 18, 2016.
  1. Hi guys, iv got a problem when driving my car under boost, it's judders like loads of flat spots only under boost tho, any help would be much appreciated
  2. Could be either ignition or fuel, have you recently serviced the car? If not the first thing I'd check is spark plugs, connections to injectors etc. Check for anything obvious. If you can provoke it into throwing up the engine management light you can get the codes read.
