265 Is my DMF ok or not?
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by rick293, May 3, 2022.
  1. Hi Guys,
    So I removed my gearbox to replace my clutch and DMF (to replace leaking crankshaft oil seal) in my 265.
    I really don’t know if my DMF is ok to reuse. It was showing no signs of wear that I know of.
    Here’s a couple of videos and I hope you can give me your opinions
    Thanks,
    Rick
  2. D_K
    D_K
    You need to measure the total movement in millimetres .
    The repair manual states a limit for the amount of movement , off the top of my head its around 30 to 40mm
  3. ianplymouth
    I was told that 9 teeth movement is acceptable
  4. Do you have a link to the repair manual?
    Its getting a new flywheel. I compared the movement to a new flywheel and its night and day. Even though there was no symptoms before removing the gearbox, I don't fancy having to remove it all again when/if symptoms occur.
