Is a drive shaft washer needed with H & R springs?
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by Michael Pope, May 12, 2018.
  1. Going to be fitting some H & R springs to my Mk3 Megane rs next week, is it recommended that a drive shaft washer is fitted at the same time?
    Or are these washers more so for cars lower than the 35 mm drop the springs will give the car.
    Just made some at work just in case.
  2. No they're not needed.. I was told they do more damage than good.
    I have H&R springs and no washer, and I've had no issues.
  3. Well the washer will cause damage if fitted when not needed like with lowering springs, if going super low ie tyre is up into wheel arch then that washer is nessesary
  4. Cheers for the info guys, I'll put the washer in the shed....... for now.
