iPhone MP3 connection to carbasse audio in RS175
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by L-1011, Apr 21, 2015.
  1. Hi I've got a 2008 RS175 fitted with a carbasse head/amp unit which is if the update list type.
    Is like to connect the music on my iphone to it.
    I understand you can get a fly lead that attaches to the aux in socket at the back and has what looks like a 3.5mm speaker jack that goes to the iphone. Lots on eBay.
    Can anyone recommend me anything? Tips etc?
  2. a connects2 will charge it for you and allow you to use it through the controls next to the steering wheel.
  3. connects2? Where would I get one of these? Sounds ideal.
  4. On the cabasse system its not quite as simple, it doesnt just plug in, the plug has to be cut off and the wires fitting into the plug of the unit under the seat. Theres a guide about it if you google it
  5. Ah right! That because the actual head unit is under the seat in this one?
    There's me getting excited about plug and play Bluetooth.
  6. That's the ph1 you are thinking about. The ph2 cabasse units are in the dash only. No amp needed.
  7. Great!
    So I can use a connects2?
