R26 Intermittent Toxic Fume Filter Warning Light
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by eddie ninja, Jul 19, 2017.
  1. So this started flashing briefly on start of way home from work then stopped.
    Then about 20 mins later as I went thru the gears smoke came out exhaust and warning light came on again and engine was running a bit rough.
    What can cause this? Is it more than one thing? Should I just give my local garage a Direct Debit????
  2.
  3. This has to do with your lambda sensor and I might be wrong cause I'm not a technician but I know that the second lambda sensor deals with your car fumes but someone more versed will probs give you an answer but I'd get to a diagnostic tool
    Sent from my P1000 using Tapatalk
