Hi guys My r26 occasionally shows electrical fault with a yellow spanner on the dash but a code read shows nothing useful and the car still works perfectly, sometimes it last a few seconds sometimes a few minutes. Any ideas what could be causing this? Thanks
I still have the issue, no idea what's causing it sometimes it doesn't happen for weeks at a time though. Also my throttle peddle momentarily dies occasionally if you have been cruising at constant throttle for a while, although im unsure if the two are linked.
i found this http://rsmegane.com/threads/engine-loss-of-power.8499/#post-96772 Wonder if this would work? i did have a look for the brake light switch as mentioned on the above post but couldnt find it in the passenger footwell unless i didnt look hard enough
