265 Interior plastic scratch...
Discussion in 'Detailing' started by OiNK, May 18, 2014.
  1. Guys
    Anyone got any ideas or tips to remove or even try to hide interior plastic scratches? I have a couple around my cup holder. Bugs me :worried:
  2. Daz
    Buy a new one.
  3. Will.
    ^^ baller.
    Just spray it with some paint.
  4. Put a foil on it or paint whole lot.
  5. A foil?
  6. I think he means vinyl wrap which would be impossible due to the shape.
    I'd try a bit of 2500 Wet and dry sand paper mate.
    Add a bit of washing up liquid to the water and make sure the paper is well soaked, try to keep the surface wet and use minimal pressure.
  7. Self adhesive wrap.
    It could be possible, but probably time consuming.
    Sand paper + paint should be easier way.
  8. If you are careful and take it easy the 2500 wet and dry will remove the scratches without the need for painting, might need to use a little trim polish/dressing after sanding.
    If there is a person alive that can vinyl wrap something shaped like this then please send me proof and you can have my car for free.
  9. You could try painting it with plastidip.
  10. Just some paint
  11. That can be wrapped so easy... You don't get out much do ya bumblebee
  12. i'd just buy a new one, or some trim spray/gel to enhance the gloss will at least dull the scratch
  13. No way you can wrap that, I'd try some ultra fine wet and dry paper then a plastic polish
  14. Ash87
    Yeah wrap it, easily done.
  15. Not without cutting it you won't, won't be a good finish either
  16. Thanks guys, will try some light sanding with 2500 and if needed a little paint.
  17. You may be able to remove with some fine wet sanding but risk damaging the texture of the plastic.
    Worth a try though as only other options are painting or replacment parts from renault
    dave
  18. Not sure how easy it is to remove but you could get it Hydro dipped
  19. I have a 250 cup 'cup holder' for sale £15.00 they are £60 new from renault exactly the same as your colour ect its used but in great nick. If interested message me on here.
  20. Sand it down and paint it satin black as Ed China would say
