Intercooler hose
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Lopes3d, Jun 15, 2021.
  1. 0845E5E0-756A-478E-A467-6981B091FECD.png Has anyone fitted the the intercooler pipe pictured, the bigger one of the two. Just been up to EFI and keeps coming off on boost intercooler is an airtec stage 1
  2. matt e
  3. Is it coming off from the intercooler via the hose clip ?
    I have stage 1 airtec as well and had no issues with it before or after the hose change
  4. Guessing its either the jubilee clip that holds the sealing connecting piece to hose not located correctly or the spring clip itself that holds the sealing connector to IC is not located correctly, if drop the front section of undertray (let it hang down on rear fixing bolts) you should get a good view of which connector is slipping off
  5. The silicone hose was just pushed on the intercooler without the original clamp. After reading the other thread I’ll get my old hose and take off the adapter and use the OEM clip for the intercooler
    bobsan and Rensport225 like this.
  6. use jubilee type clip not Miklor to secure adapter
  7. Will do is there any reason for this?
