Intake problem
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Aaron, Oct 2, 2017.
  1. I recently fitted a injen cold air intake into my 2011 megane rs and everything has been fitted and connected but when I go to start the car there is a single click noise coming from the right side of the engine (where the battery is) but the battery is fine.a single click noise happens everytime I go to press the start button. I was wondering if anyone had the same problem or if anyone can help me out. Cheers
  2. If the battery/connections were removed, make sure they have a tight connections, as this can sometimes cause a click/spark. Check all the simple things first.
  3. Will have a look at that tommorow. Was wondering can there be a problem with the ecu connection im pretty sure they are done correctly. Thanks for the reply appreciate it.
    Mikey4410 likes this.
  4. Anything that has been pulled/pushed check. Let us know how you get on.
    Aaron and Mikey4410 like this.
  5. matt e
    check you havent broke a earth lead
    Aaron likes this.
  6. I had a look today it was just a loose connection. It all good now the car sounds amazing
  7. It was just a loose connection.
