R26 Inner Door & Rear Panels Removal
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by R26Man, Aug 27, 2015.
  1. Hi,
    Have to remove door cards and rear panels and wondered if there are any tips or tricks before I start!!
    Thanks for any advice and input from those who have gone before...
  2. Front door cards a little fiddly.
    I used a teaspoon to start:
    Get off the mirror fixing cover, door handle (bottom first and prize out), electric window swtiched, and finally the door pocket (fixed with 2 plastic clips -open up and push nearest side away from you firmly to release and then pulls out easily)
    3 or 4 torx and 2 bolts holt the card in place now - the torx are 2 on the door handle (one at top and one at bottom), one behind the door handle that moves (plastic cover on it) and one somewhere else I can't remember. The 2 bolts are right at the bottom of the door card.
    The whole thing should come apart fairly easily after that.
    Hope that helps a bit mate.
  3. Thanks for coming back with that...especially the teaspoon idea!! Thanks also for the commitment to the cage...let's hope we get some others with interest AND money!!
