1. Hi all, could anyone tell me if standard injectors are a straight swap or if the new ones have to be programmed in?
    Jake
  2. They're a straight swap, takes about an hour if you haven't done it before.
  3. Great thanks. Do you know where the best place is to get them from? Thanks
  4. I shall be removing standard 225 injectors very shortly if you fancy a bargain ?
  5. MBC
    MBC
    How many miles have they done?
  6. Car has 54k on it, runs very sweet. No idea if they are the originals
  7. Mine had them changed at 47k and the new set have lasted until 58k and need changing! I spoke to the mechanic when I had it serviced and he said its luck of the draw a lot of the time!
  8. MBC
    MBC
    Thanks mate. I'll probably pass
  9. I did a guide on changing the injectors in the guide section :wink:
  10. just changed mine with a second hand set and best move I ever did mpg gone up 4mpg to 26 and it drives and sounds a lot smoother
