Injector Seals
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Ian Hughes, Jun 20, 2016.
  1. Hello. I have had my injectors cleaned out by a member on here not that long after, it started to cough now and then at idle. Unfortunately its got gradually worse. I have read on here that some people have experienced this and went on to change the o rings on the injectors and their cars have been fine since. I was wondering where people have got these from? If they are cheap enough Im going to try it before I buy new ones. Ian
  2. Hi Ian,
    If anything that has a seal is removed after being in place for a long period of time, it will need a new seal due to the fact that you will never be able to get the seal in the exact same position as it was before it was removed, this will be the same with any rubber seal.
  3. Ian, although I think you should replace the seals, this might not cure the issue
