Induction kit for 225 Trophy
Discussion in 'Wanted' started by JamesW, Oct 20, 2015.
  1. As per title, will consider most options. What have you?
    cheers
  2. I use on mine and theyre only £30 brand new on ebay the ram air cone. It just fits on to the end of the existing hosing all you need to do is remove the air box
  3. I have a DIY ITG kit that I could be tempted to sell, ill put pics up when I get home tonight :smile:
    its with the maxogen ITG filter and Red 90 degree bend and all associated pipework
  4. I use the above but with the Jetex filter. Sounds awesome with the forge recirc valve. I did think it was too quiet but since fitting the yellow Spring to the valve, removing the bonnet padding and engine cover it sounds ace, wouldn't want it any louder tbh. Also fitted a slightly better cold feed, wether that helps I'm not sure
    It interfaces with this cut down std turbo pipe
  7. Cheers lads, I found a thread talking about the DIY ITG and that seems a cost effective solution.
    Torch - thanks for the offer. PM me with a price inc postage, I'm in Southampton.
