Does anyone know where I can get a stud kit for the ignition coils? 2 of the threads have been cross-threaded so will need repairing and then a stud kit put in.
I'm not sure, I did speak to someone about it they said it's common on these cars so they just suggested a stud kit.
I’ve got a R26 and there 6mm thread because I’ve had to tap and dye 2 of them to 7mm when I have time I’ll be doing them all to 8mm and ordering a couple 8mm Allen key bolts to look like the rest I brought from pure motorsport. Sent from my iPhone using Tapatalk
I just ordered this from K-Tec http://k-tecracing.com/show_product.asp?id=6100&appid=20 Will I still need to repair the thread or can I just push it in and loctite it?
looks like need to screw the new bolt in to existing hole (prob with Allen key) then install coilpack then tighten nut, and yes I would put loctite stop it unscrewing
Problem is the thread is either stripped or cross-threaded so it won't do up, will this need repairing or could I just hammer it all the way in seeing as it doesn't have to come out?
wouldn't hammer in, not sure how this product works but at guess you'd screw into existing cross-threaded hole and it makes its own way in as a permanent thread maybe
