Idle problems r26
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by L.maddern91, Dec 6, 2015.
  1. On the scan gauge the idle is fluctuating between 710-780 but then sits steadily 750/760. Every now & then theres a deep...pop/bang/rumble its hard to describe.
    You can feel the car slightly judder when stationary, no problems when driving/on boost.
    Im presuming injectors? But wouldn't they give me problems when on boost also?
    Cheers. Lee.
  2. I have the exact same problem, I had new injectors but it still does it.
    It has been suggested to me that it could be a worn throttle body, or it's a bit clogged and may just need a clean
  3. Ill try get mine off at work tonight & give it a clean. Ill let you know
  4. Inlet side
    Outlet side
    Outlet cleaned up
    Refitted. Just waiting for the car to warm up, monitoring on the scan gauge.
