Hybrid turbo how to?
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Haomaru, Dec 23, 2014.
  1. Hi, im after a hybrid turbo, just wondering how hard is to install it, thinking on do it myself. I understand it is a direct swap, do i have to move the engine?
    Already got a decat fitted (i dont put this one) a forge dv and actuator.
  2. Depends on the hybrid if it's just hot side then you don't need to replace all the turbo else doe pipe off undo bolts from bottom and out the top 3-4hrs work.
