1. I need a lil advice here please.
    I've been seeing some grease on the inside of the hub and even some grease spats on my rim, could this grease be from the swivel hub bearings or the wheel bearing cause it's not from the CV boots as they are still intact.
    Anyone?
    Sent from my VIVO using Tapatalk
  2. Sounds like cv grease... are you getting any symptoms like knocking or wheel bearing noise? Cause if not I'd say you've got a split cv boot.
    Sent from my HTC One_M8 using Tapatalk
  3. This grease by the way... If you had to give it a colour, what would you say?
  4. I took off the drive shaft inspected the boot and even replaced the boot on the other side but I'm not getting any play on the wheel bearing tho or any knocking noises to suggest CV joints
