Hi, The picture below shows the current situation that I'm in with removing the hub off my megane. How on earth do I get this bolt out, any ideas? Thanks, David
The problem I have Mark is when I turn the nut the threaded part turns. How do I stop this happening?
Get it booked in with Mark Black. He makes it look easy. One of these may help: http://www.halfords.com/motoring/garage-equipment/car-tools/laser-ball-joint-separate-fork However, if the thread is spinning, I'd be worried about the balljoint being knackered?
Think I'm going to get it off and send it to Mark to be reconditioned. Yeah ball joint worries me but il deal with that once it's off haha!
I used a ball joint splitter but in saying that my bottom arm was nackered so I wasn't fussed in destroying it lol Can you not jack up the hub in anyway so that the bottom of the hub touches the nut again creating pressure so that you can undo it more, just a thought
Get a pair of grips on the ball joint, Push the lower arm down and it'll give you enough room to grab it
