As above having trouble removing the suspension. Removed the top drop link off the shock and the main bolt on the rear that goes through the shock and no luck. any techniques needs etc or am I missing something help needed asap thanks Matt
You need to take the hub off 1st then the strut. The hub won't go down far enough to get the shocker out.
