250 How to remove the rocker cover?
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Charlie Howard, Sep 12, 2021.
  1. Charlie Howard
    What's the process of removing the rocker cover on a mk3? Wouldn't mine getting mine cleaned up and painted if it's not too bad.
  2. ianplymouth
    You will have to remove the turbo beforehand and that's a real ass of a job, believe me pulling the engine would be easier for removing the turbo.
  3. Charlie Howard
    Oh really why does the turbo need removing?
  4. ianplymouth
    Because the outlet from the turbo is so close to the vent plate and rocker cover, you need to lift the rocker up quite a bit and that aint going to happen with the turbo fitted.
  5. Charlie Howard
    Oh that's annoying, nevermind then
  6. ianplymouth
    sorry :confounded:
  7. You could clean it in situ. Just use lots of tape and plastic
  8. matt e
    the rocker cover holds the cams in place so you'll need timing tools as well
