How to fit small boost hose?
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Krissg, Feb 28, 2014.
  1. Hello.
    im after some help yet again.
    just wondered if anyone had any tips on fitting the small boost hose that goes on top of the engine. (The hose that is supplied with forge intake)
    do I need to remove the pipe or anything or is it just a case of brute force and patience? Cheeeeeers
  2. It would be easier if u took the bolts out the Pipework so u can pull it only takes a min or 2 to do
  3. Remove both of the fixings... One on the brace mounting and one on the manifold and then just wiggle it on from there really. A little WD40 helps
  4. Are you referring to the jubilee clips or the bolts holding the pipe on? I did have a quick bash at just loosening jubilee clips but it was dark, I could have probably pulled the old hose out but getting the new one in would have been the issue! Haha
