How the hell do you get to the lower bolt on the standard recirc valve on a 225 ?!
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by DrewG, Jul 18, 2015.
  1. Evening all
    Think I have an issue with the standard recirc valve fitted to my 225, she's not holding boost under full load - dropping from 1.1 bar down to 0.8 / 0.9 randomly. Have purchased a 2nd hand replacement unit from one of the guys on here...
    Just been out for a nose under the bonnet to suss it out before it arrives, have located the valve and the top two bolts; which look simple enough, but the 3rd lower most one >! WTF :confused:
    Any hints / tips ??
    Drew
  2. Magnetic Flexi extension bar ? :confused:
  3. All you need is an offset spanner mate
  4. Ovy
    Ovy
    This job is made much easier if you remove the inlet pipe.
  5. Cheers guys
  6. On a 250, job is easy with inlet pipe removed.
  7. this a 225 mate
  8. Take inlet aout, use an 10mm spanner
