R26 How do I replace passenger side heated wing mirror glass?
Discussion in 'Exterior & Bodywork' started by LYR26, Jan 21, 2015.
  1. Hi
    Someone's clipped my passenger wing mirror, thankfully it's only the mirror glass that got damaged. I have the replacement glass, but I have no idea how's best to remove the smashed glass (backing to the glass is still all intact) and how to put the replacement on.
    any advice would be gratefully appreciated.
    :-) Lynette
  2. It should just prise off carefully with a screwdriver or two.
    Shouldn't need much force, just stick them down behind the glass and lever towards you. There should be an electrical connector on the back so watch for that too.
  3. Thank you! :-)
    An electrical connector? Oh gosh. Do I take that off and connect it to the new glass?
  4. [​IMG][/URL][/IMG]
    purple wire with connector block connects to back of glass..
  5. Thank you so much for your help! All done
  6. Brilliant! Glad you got it done :smile:
