Horrid clicking noise turning left
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by odinson, May 2, 2015.
  1. So had me megane a week now and I've noticed a horrible clicking noise from the front right on low speeds or when turning left. the cliclicking can still be heard at say 30mph? Now I've read a few bits on here about the H&R springs causing a slight knock but this isn't as such a knock but like I say a click, to me almost sounds like cv joint.
    Anyone else with the H&R springs had similar clicking? Or anyone with out them?
    Will try and get the wheels off etc to see if I can locate the noise
  2. Maybe the bearing on the drive shaft mine was doing the same = new drive shaft
  3. Ahh really! How much was that
  4. Cv joint??
  5. Naith
    Cv joint plastic.
  6. Yeah , sounds like CV gone.
    £12x from Renault
  7. Naith
    Is that how cheap they are? That's good, I thought they were a lot more?
  8. can you change the joint only then, and not the whole driveshaft ? i have the clicking on the o/s when turning right..
  9. Naith
    Yeh but check if it's ripped or not. If it's still in one piece a lot just repack it with grease and retie it with a metal jubilee clip.
  10. Probably the lowering springs
  11. Cheers guys. And Ryan I've read about the H&R springs causing a noise bit can't imagine it being this
  12. Driveshaft when mine did it, cost about £220 fitted from Mark Black.
  13. That is for the whole shaft.
    Should be able to get the shaft direct from Renault , then an hours labour to change per side.
