Hello, my name is Simon, I amd 29, and I am from Novo mesto, Slovenia. I had a Racing Blue Clio 200FF Cup since new, from April 2010, and now I have switched to a white Megane 265 with KW V3 Suspension. Other mod is only the deleted precat and a direct exhaust back from the center silencer.
Nice cars mate. Nice mods on the Mk3 as well! - I'm sure a performance brake pad compound will transform the brakes, with new fluid as well - its a good cheap way to get a lot more performance from the meganes in my opinion, with keeping the standard discs!
Yeah I had the Motul fluid in a Clio aswell, will get it for the Megane too. First I need to strip and clean the brakes, because they arent as sharp as in the Clio atm. The ones from Clio had to be cleaned every year to stay sharp, I assume the same applies for the Megane too, due to the similar brakes. Are the Brembo pins the same on a Megane, because the calliper is a bit different than on a Clio. I have a spare set from a Clio left, just in case if it fits?
