265 hesatation
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Trophy irl, Apr 24, 2016.
  1. Hi guys
    i have an 2011 265 trophy and every now and then it hesitates to respond when im accelerating its not there
    when i take off but from about 50mph the car has a fast chip remap and
    i have put in new oe plugs cleaned the filter but still there its a pain
    anyone have the same problem i read that the map sensor gets a bit dirty (could that be it) and how would
    you clean them
  2. I take it you have a performance panel filter that you have cleaned and re oiled. Maybe you have over done it with the oil! If I was you I would take out the filter and leave it to dry naturally in the sun and clean you MAF sensor with a dry electrical cleaner.
    Should do the job!
    Report back on your findings.
  3. The filter was well dry when I put it back in is the m a f easy to clean I think on of the lads on the site had a similar prob
    and he cleaned the boost sensor with a cotton bud and I think it fixed the prob I will try that over the next few days any one got pis of where the maf sensor is
    thanks
  4. Isnt it the sensor on top of intake manifold?
  5. Pretty sure there's no maf.
  6. There isnt any MAF sensor on those cars, it is running with MAP sensor.
  7. -Jamie-
    They have two map sensors, One on the Inlet and one on the cold side boost pipe.
  8. ok thanks guys ill try and clean them and go from there
