250 Help urgent
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by Zs_phil, Feb 14, 2016.
  1. Hi all done my thermostat today unplugged ecu and everything now put it together and it's gone nuts
    No lights brake lights night lights and braking error
    Also the rsmonitor was working but no now
    Is the ecu learning or something wrong
  2. Sounds like something is wrong.. Did you reinstall all ground connections properly?
  3. Nothing electrical works
    Just says on dash battery charging fault and braking system fault
    Re checked the wires looks right
    Only thing working is drivers side light and the drls
  4. Does it run then ? Something short circuit.
  5. Has anyone got a pic or could get a pic for me of the battery connectors hoping I've done them wrong
    Had ecu out again and it's all clear
    I've read about a fuse on the positive battery terminal on the Mk2 does the mk3 have this
  6. Yeah runs and also locks and unlocks
  7. Check all the fuses in the bcu its near the battery and its upside down
  8. [​IMG]
    Just been out to the garage for a little look fiddled around with this box and a light inside kept going on and off so I've probably disconnected something putting it back together or not put something back right
    Luckily don't use a car for work so can wait for another night or weekend
  9. All done no idea what it was just dismantled it and redid it and it worked and everything seemed the same
    Tempermental shiela she is
    Only thing is blew one headlight but I can live with that
  10. Bet that's a relief :rolleyes:
    Glad you got it sorted, sort of.
