Help removing forge dump valve
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Tex, Jun 11, 2020.
  1. Tex
    Tex
    Can anyone provide a dummy-proof guide?
    Some pics. Looks like the stock re-circ valve and vacuum is there I guess I remove the T and connect the stock vacuum pipe to the recirc.
    I'm just not sure where the very large silicone pipe would be connected (or where it goes) once the dump valve itself and forge silicone pipe is removed.
    Thanks in advance
  2. You have both the recirc and a BOV there. Should it not be one of the other? The pipe from the recirc joins the T piece to the right of the engine and, as you have probably figured out, the silicone hose would usually go to the sound generator.
