Help needed
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by olivershep225, Jan 25, 2016.
  1. Good afternoon,
    My friends 225 cup has gone into limp mode and is kicking outfault code po243.... [h=1]Turbo/Super Charger Wastegate Solenoid "A" .[/h]Does anybody have any knowledge on this and knows what the fix for the issue is?
    T.I.A
  2. Easy fix. Just source the part and swap. It gets caused by water running over the sound insulation and onto the solenoid. Worth getting the bracket that stops the insulation sagging.
  3. Cheers guys! Just to clarify do you know if its the valve on the intake pipe?
