Help Name the part
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Luke90, May 13, 2015.
  1. Hi Guys
    I Recently purchased a F1 225
    It needs a few areas cleaning up and a little bit of loving
    I noticed a hose that has been split and bodged back together, My issue is trying to figure out what the hose is called
    I have found a couple pictures online and circled the part I am after. Any help will be greatly appreciate!!
  2. Vacume pressure hose i think most people feck it other end when fitting dump valve reno only part
  3. Cheers chap!
    Have been in touch with Renault direct for the part, the hose is on back order!! however the filter is not so fingers crossed I can cut the hose short and make do!!!
