Problem with my 250cup.. It's making a high pitch tone at anything over about 20 and when I've come to a stop I get a small shudder. Any ideas?? Thought it was a pulley on the belts but spent a small fortune on new aux cam pulleys and water pump today and still there
The local garage said the shudder could be a broke abs ring.. tbf they were scratching there heads. I told them the 2 things happened at the same time and came on all of a suddon
The noise is all the time only when moving in gear aswell as out and when you steer the car left and right the noise just stays the same ??
Hmm... based on that could be the gear bearings. Take it to a gearbox specialist, they should be able to tell your straight away
Rs specialist in Doncaster thinks all the noise is just badly worn inner edge on my front tyres.. just got back from there now for a second opinion
