I have a Megane Rs 265 cup. It has problem with the drive shatfs. My question is, can i get stronger shafts than the factory made?
Heya there. As with any car you could have custom driveshafts made pretty much to ure spec but they will be costly.can i ask why it is u need uprated shafts ?
Hi! I'm Tamas from Hungary. I'm new member here. I'm looking for contacts who can help me to find a solution to my problem. I have a megane III rs 265 trophy (cup). I faced the problem that, when puss the throttle harder the car starts wobbling. But in that case if push it softly, noting happens. I took the car in a workshop where they fixed the problem. They added, it won't operate perfectly so long time. I need to change the drive shaft. I drove it approx 1800 kliks and it starts wobbling again. The car don't has extra power. There are 68000km at all. I use it normaly. My plan is to buy a set of drive shaft what is stronger than the original. I would like to ask for adcive,where can i buy stronger drive shaft for my car? What do you think about K-Tec products? Thanks in advance for your help!!
Hi Tamas. As you state... the car does not have extra power...I would not think you need stronger drive shafts, but the guys on here will advise you I am sure.
OK! I believe you guys. It is just incredible for me that it could be wrong under 68000 kliks, in normal use???
Sounds like there is something else wrong, try taking it somewhere else? if you are not running extra power, why would need uprated ones? when 100's of other Meganes are fine, and running more power
Is the car lowered? You can potentially have issues with your driveshaft if the car is lowered more than 30mm
