Helix pressure plate bolts
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by BG5WRC, Aug 7, 2017.
  1. Hi. I went to fit my helix clutch and flywheel with new genuine clutch pressure plate bolts but they wont fit, they are too short to start tightening.
    Have I been supplied the wrong bolts??
    As you can see the clutch pressure plate is up tight against the clutch.
  2. These are the bolts
    kjl
  3. For the next person with the same question, the answer is that I needed to reset the pressure plate and remove the tension/pressure - then do up the bolts and re-apply the pressure.
    Terry D likes this.
