R26 Heater Blower Fault
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by BEEFTEC, May 15, 2016.
  1. Interesting that I come on to query this problem and see someone else suffering a similar fault on their 250!
    But I thought i'd start a new thread as my problem is different and different car so I assume different solution.
    My heater blower on my R26 works... mostly. Basically when I first start the car, sometimes the blower won't work at all for the first 2-5 minutes of running. Other times it works fine!
    When it does kick into life it works perfectly, all speeds work etc.
    I've done a bit of research, sounds like the resistor pack is the common cause of problems and there are companies offering to fix it for under a tenner:
    http://www.heaterblowerresistor.co.uk/renaultmeganescenic2heaterresistor.html
    However I can't see it mentioning my specific problem. i.e. mine works fine but sometimes not for the first few minutes.
    Anybody else had this - Very strange?!
  2. Mines works fine on settings 1,2 and 3.
    But not at all on 4.
    Not had a chance yet to see what the problem is!
