Heated wing mirrors problem
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by CJ_RSport, Oct 24, 2013.
  1. CJ_RSport
    CJ_RSport RSM Moderator
    Hi guys does anyone know what to check as my passenger mirror wont demist first time I noticed this morning
    Popped glass off and checked connections on
    Could it be the element in glass gone?
  2. My drivers side is the same and I did the same.
    I don't think these are too much to replace are they?
  3. CJ_RSport
    Dont think so going to check the heater wires with a bulb as multimeter packed in and see if theres a feed if so gota be element in mirror
  4. Did you try the bulb?
    I've ordered a new mirror glass off ebay - wanted it sorting before winter sets in. Think it was about £11
  5. CJ_RSport
    No thankfully just started working after cleaning contacts pal
  6. You need a multimeter to test but for anyone else, you should have 12-14v at the terminals with the rear heated screen on and test the mirror element resistance itself with it disconnected.
  7. Gavin.
    Gavin. RSM Admin
    Mega bump! Glad i found this, my drivers side has never worked, i'll get the contacts cleaned.
