Hi all Is there a separate washer fluid reservoir for the headlight washers on the mk3, or is it from the same reservoir as windscreen washer fluid. i have the headlights on, windscreen reservoir full to the brim but can’t hey it to work so wondering if a separate reservoir which needs filling thanks in advance
but i don't think they work every time the windscreen is washed (with the lights on), thought it was every 5 or 6 washes
Yes it’s very random when it works! It’s also comical the amount of spray the headlight washers produce. No wonder the water needs topping up so often in the winter!
