head unit problem
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by fazmo, Oct 7, 2015.
  1. hi changed the radio in my 225. works fine until I increase volume over a 1/4 and it cuts out. also if I turn steering wheel full lock and if I press both window switches up. seems like when theres a drop in power theres not enough juice to keep it powered. I have a kenwood flip screen. any help would be greatly appreciated.
  2. Sounds like you have a connection issue, check your ground and live, did you use a connector or have you spliced in to the loom?
  3. hi I used the 5m iso extension loom as the wires were in boot. also same problem if ignition turned of stereo turns off. then on but before it can play any sound turns of again. Might see if I change battery may fix
