hi all went out for a blast in the megane last night - first time I've driven it at night and the lights seem to be pointing at the floor with no way to adjust I've a recent receipt from renault to say that the front height sensors have been replaced and that the rear sensor is corroded but not producing an error code. does the rear height sensor need replacing? is this a common issue? cheers
Check the sensors, quite common for the plastic bars to come loose/disapear. There is manual adjustment on each headlight, normally a hole with a white plastic alan screw inside.
