Has she already been mapped ?!
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by DrewG, May 2, 2015.
  1. Evening All
    Recently purchased an 06 225 Meggy, and have just managed to find my old RS Tuner and have plugged her in !
    Looking at the Programming History, I see an entry from an "RS004319" device... several programming entries in the history.
    Could anyone that has an "RS Tuning" map confirm to me whether this is a similar entry ? Assuming that is you have the ability to check your ECU..
    I've mailed Henk at Fastchip but thought I'd check on here too.. I don't recall a similar entry on my old 172 when I'd mapped with the 98 Ron from them.
    Also a couple of entries from an "F SAG" programming tool...
    Attached is a screenshot of what I see..
    Thanks in Advance
    Drew
  2. RS004319 being 3 years after the car was made.......
  3. Just check your peak boost
  4. No guage on the car bud..... :worried:
  5. You have an rs tuner..... You can log boost
  6. Assuming that will need a new connection licence..?
    Cheers for the help
  7. What would peak boost normally be MJ ?
    Just purchased new connection licence for the box...
  8. Just looked up on meganesport.net and stating 14psi / 0.9 --> 1bar standard..
    As soon as I have the unlock code from Henk for the Tuner I'll check.
    Interesting, I had the belts done a couple of weeks back at Beeniesport in MK who commented on the pull.. and questioned whether standard or not... as far as I was/ am concerned, the car hadn't been mapped.. but maybe that not the case... could save me a few £ :cool:
