Handsfree Systems
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by craig180, Dec 3, 2013.
  1. Does anyone use a handsfree kit such as the Parrot systems in theire Mk2 megane with the factory upgraded Cabasse Auditorium?
    If so, what are you using and is it simple to fit?
  2. There was a Parrot in mine dude, I took it out about 3 months ago though or you'd have been able to see it the other day lol.
    It was pretty easy to remove so would no doubt be easy to fit.
  3. Is that with the cabaase stereo dude?
  4. I'd be interested in this information also; I was thinking about getting another parrot kit for the R26 at some point...
  5. Markblack@MRS
    Markblack@MRS RSM Trader
    They can't be that hard to fit,
    I fitted one in my meg and one in the wife's
  6. With the cabaase auditorium?
  7. Dunno if it helps, but I've got a Parrot MKi9200 fitted to mine and it works perfectly.
    It can wirelessly stream music or you can plug in with the ipod lead, USB, headphone jack or stick an SD into the display screen.
    I've hidden the wires down from the stereo to the panel at the bottom and fed the wires into the ashtray pot. It's pretty neat as you don't see the wires dangling around anywhere.
    You could run them to the glove box if you so desired.
  8. That is exactly the one I'm looking at so I can stream from a phone and also have my iPod wired in.
    Looks good
