Evening Chaps!! I've got an R26, And recently it seems to be handling a bit rough!! I run NS2R and they've just hit the half way point, I've noticed a knock when going over bumps at low speed but have had both drop links replaced. I've also had a mechanic have a look at it and said there doesn't seem to be any issues but it's DEFINITELY not handling the way it should, It just seems to lack overall grip on the front end and the steering no longer feels nearly as tight as it used to. Help!!
I had a similar issue, one of my dampers had gone. It only rattled if the wheel was under load so it took ages to diagnose. Mark Black found it after ktec said my steering rack was broken. The damper lost all of its fluid and the handling and steering went out the window. Do you have any play in your wheels? Mine had slight play
