250 Green dot actuator
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by hsustyle, Jul 20, 2023.
  1. I'm after a 250 green dot actuator,mine is failing.
    Seems impossible to track one down. Anyone know where I can get one?
    As pictured -
  2. What problem do you have with the actuator? I ask because I don't think mine is the best either.
  3. ianplymouth
  4. All sorted. The actuator was fine. I was getting a slight dip in boost on full throttle between 3-4k rpm. Had it with a couple of specialists and mapped again by engine dynamics.
    I have a spare green dot one here, fully working, £75 posted
  5. ianplymouth
    It will work on a stock turbo, the Forge one is supposed to be shite, was told by the guy that maps my car, that he's seen loads of problems with them
  6. depends on the spring right? I have one of these external Forge actuators with the red spring which is the stiffest of the lot rated at 20-23psi on their website. Ive also heard the forge one isnt as good but i reckon its coz of the spring right?
  7. Do anyone of you know ther spring rating for thew MEG 3 actuator, I have a forge one with a red spring in it, So i dont know which actuator to use.
  8. ianplymouth
    Not sure what the spring rates are, but was told a Mk3 one is an upgrade for a standard or hybrid turbo, along with a map
