225 GPI intercooler from ebay-635 mm X 244 mm x 60 mm
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Liviu, Nov 27, 2023.
  1. Hello,
    I just purchased a GPI intercooler from ebay (151 gbp) , core size:635 mm X 244 mm x 60 mm (tube and fin) , 4.6kg (10.14 lbs)
    As it is build , looks ok, but my doubts are related to the core tube and weight (which is a bit low). This main tube is made out of other smaller tubes, not fins, like I have seen on other intercoolers.
    I will be using it on a megane 2 RS 225hp, (bc racing coilovers, ecb brakes, yellowstuff pads) by replacing the stock intercooler. Probably in the near future , would want to make some power upgrades up to 260-270hp.
    Note: the car is meant to be used from time to time for track day.
    Is it worth it keeping it? Or should I send it back ?
    pictures attached with the intercooler.
  2. These have been proven to be ok up to about 280bhp, anymore it’ll need upgrading further.
  3. Had the same one on mine and charge temps were pretty poor when logged 20+ degrees above ambient, not good.
    Changed for 70mm airtec which moves 2deg above ambient.
