265 Geo setup - more track focused
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by D7DPJ, Aug 26, 2021.
  1. Hello All,
    So after a full suspension refreshed with new cup shocks, dampers, Grams lowering springs and fitting of some semi slicks, I feel im a little more track capable now. I am also having some Silver project top mounts fitted next week. This will give me the ability to adjust camber and caster.
    What i'm looking for is a rough idea on geo settings that I can give to the garage to be setup more track focused. The car is a daily but daily is a loose term I would use, im happy to be fairly track focused.
    The silver project top mounts I think allow around -2.2 on camber, so will likely be setting them to max. But not sure on caster and toe settings, would be great to know what people are running.
    I know its also slightly personal but I wouldn't mind a starting point :smile:
    I will also be finding out the rear camber so I can adjust with shims, so dont be shy share your full setups.
    thanks in advance
    Dan
