Hello all, does anyone else get this ? 4th gear for example, cruising and 30-40 when letting off and then applying throttle again the gearstick moves and you can feel a knocking through it ? I was thinking about replacing the dogbone/stabilizer mount for the vibratechnics one to see if that cured it... I'm a little worried that its coming from the gearbox, unless the lsd has something to do with the movement ?
I have this as well mate, still unsure if it's normal or something is playing up, mines not that noticeable but you can feel it vibrate when going on and off the throttle. Will be interested to see what anyone else thinks/experiences.
Yeah I have no idea if it's normal or not. I feel movement through the gearstick when going on and off of the throttle.
I take it you have had this problem ? Are you speaking from experience or just saying its most likely to be that one as the lower didn't do much ?
