250 Gears Grinding
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by tchubacca, Oct 27, 2014.
  1. Since having my car from March this year I have noticed that when putting my heavy right foot down, I sometimes go from 4th to 6th and there's a grind like I'm not pressing in the clutch enough. Any ideas?
  2. Don't go from 4th to 6th...
  3. I can confirm that it is correct solution.
  4. Press the clutch in more....
  5. bit of mechanical sympathy may go a long way.
  6. Why would you go 4th to 6th while pinning the throttle? I mean, block skip gears sometimes but only if say getting up to speed on a slip road in 4th and then fairly slowly change up to 6th with minimal throttle once in 6th.
    Never grinds though, only gears a find a bit rough are 1-2 and 2-3 when pootling about and if you try to change with very low revs.
