250 Gearbox
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by jimmy, Jan 10, 2016.
  1. Has anyone changed one on a 250? Thinking of upgrading my non diff to one with a diff and was wondering how much works involved.
  2. Hi Jimmy,
    I just had this done a month ago! First off, you simply have to do it as it transforms the car. The corner exit grip in both wet and dry is massive. I am not kidding when I say I could not own another powerful fwd car again unless it has a diff.
    As for the work involved, it's a fair bit, but doable by someone that knows their stuff. Renault state 11hrs to change it and my local garage wanted £600 in labour as a result, as did a couple of others. However I went with a trusted trader on here Mark Black at Midlands Renault Specialist who changed it in 4hrs flat and as a result a damned sight cheaper than £600!! Definitely need to know your stuff though and its a 2 man job which personally I don't think is doable without proper lifts.
    Hope that helps?
    Nath.
